20x9 wheels with 10mm offset?
That should work out to about a 5" backspacing. Stock is 6" I believe
My wheels are 20"x8.5 with 5.5" backspacing on a 6" fabtech and everything fits geat, fabtech only sugests 5" but with the larger diamiter wheel there is more room for the spindles.
On a stock truck it should be perfect.
However they will stickout about 2.5" more than stock.
https://www.f150online.com/galleries....cfm?gnum=5876
According to my chart a 9" wheel with 10mm backspacing is between 5.25" and 5.5" of backspacing... So the backspacing will be right... but the wheel will stick out 2 1/2 inches more than the stock wheel. And depending on what tires you are going to run and if you have lift or not the tires being out this far could cause them to rub on the fenders.
-stephen
PS check out this site for wheel info http://www.rsracing.com/tech-wheel.html
-stephen
-stephen
-stephen
According to the chart im looking at a 20x9 with 35mm offset is over 6" of backspacing... Im starting to wonder how accurate the conversion chart is... there is someone on here with MB motoring Express 20x9 with 30mm offset and they look awesome! But, i dont like the wheels to stick out... so you might like less offset better. But either way, i think it is going to be hard to get 10" wide rims to work well without any lift... unless you run a stock size tire.
I found those 20x9 wheels with 30mm offset
its CarlJ's truck... here is a link to his gallery https://www.f150online.com/galleries...w.cfm?num=7827
