CB radio placement
Old 12-07-2007 | 12:07 PM
Nettershakes's Avatar
Originally Posted by Jolly_Green_Giant
Here's how mine is set up. I personally didn't like on the dash at all. It's out of the way and still easy to reach.
Yeah Jolly Green thats where i got mine. Velcro seemed to work great.
Old 12-07-2007 | 12:10 PM
gixxerjasen's Avatar
The mic. cord does lay against my leg but I never notice it.
That would drive me nuts. I keep my keychain unclutterd and short because I can't stand having stuff laying on my leg while I'm driving.
Old 12-07-2007 | 01:54 PM
CRF250rider1000's Avatar
I am thinking about making a little cover for all the wires and covering it with some black speaker carpeting, but that will probably be when I am super board and need something to do
Old 12-07-2007 | 01:57 PM
mattivie1's Avatar
where do you get that strong of Velcro to hold up your cb
Old 12-07-2007 | 04:00 PM
dbhost's Avatar
Wal Mart in the fabrics section. You want the Industrial Strength Velcro. Be careful though, Texas summer heat will melt the glue and drop your radio on you...
Old 12-07-2007 | 05:12 PM
OnBelay's Avatar
The rubber pad in the tray on top of the dash lifts out, and I put it in away for safe keeping. I then drilled a 1" hole at the back of the tray to run all the wires down through; tapped into the radio power and ground wires.
When I took the CB out, I simply spray glued the rubber mat back down. To look at the dash, you could never tell there had been a radio up there.
Old 12-07-2007 | 05:41 PM
Impact9's Avatar
If you have a after market single din radio you can do what I did and mount in a compatible size cb in with the headunit.
Old 12-07-2007 | 09:35 PM
Radio shack also carries some very strong velcro. It's what I use to mount my camera on the outside of my motorcycle when running at the racetrack. Normal velcro came right off with the vibration and high speed wind.
Old 12-08-2007 | 09:18 AM
Nolo's Avatar
Old 12-10-2007 | 10:27 PM
wdhigh's Avatar
I simply mounted mine to the left side of the glovebox. I thought about it for weeks, but could not find a place that it was close and out the way. All I need to get to is the power switch and it isnt that bad at all.
I ended up putting my linear under the back seat close to the frame by the jack. Way to far for a jumper in my opinion, but with the stupid bench seat and interior arrangement there is not much you can do.
Old 12-18-2007 | 01:42 AM
I actually got it from The Home Depot. Its some sort of outdoor heavy duty velcro like 3$ tops.
Quick Reply: CB radio placement
