Right Rear Tire Stick Out Farther than Left Rear Tire...Anyone Else?
I was just wondering if anyone else's right rear tire seems to stick out a little farther than the left rear tire if you look at the truck from the rear? I noticed this the other day when looking at the back of my truck and noticed that the right rear seems to be sticking out a little more (like 1/2" or so) than the left rear so I was curious if anyone else has noticed this on there truck? I know it sounds weird but it is something I was curious about and wanted to ask and see if I am the only one that can notice it.
This is on my 2010 FX4 Supercrew.
Yep, and the service director gave me some BS that it must be normal since they are all like that on the lot. Even tried to demonstrate to me on an older F150 on the shop rack that it's the axle shaft with some play in it, but I think it's been determined that it's the mounting points on the bed that are crooked. The wheels are in line front to back, and the cab matches up with the front of the bed.
I took my screw FX4 back to the dealer when I noticed it. They set the alignment and told me all of the new trucks on the lot were the same and I had to live with it... It hacks me off because it was the same with my offset bed on the 05 F250... They just told me they are all the same and to live with it.
Mine is the same. If you look real close the bed is to the driver side just enough to do it. It looks almost lined up on the pass side between the door and bed but the bed sticks out a bit, maybe a 1/8 or less on the driver side. I noticed it when i first got it but before I raged I went to the lot again and sure enough they were all different. Most like mine some off to the other side. I realize that they probably don't have a dude with a straight edge making sure before they bolt it down.
