2005 F150 Fog Lamp Wiring Diagram
Old 08-26-2005, 11:02 PM
jsimcox's Avatar
I'm adding an extra set of fog lamps and I want to connect them to my factory fog lamp switch. I'm looking for the wiring diagram for this.
Old 08-26-2005, 11:58 PM
vigness's Avatar
Swing by the dealership and copy page 86-1 out of the electrical manual
Old 08-27-2005, 05:03 AM
asinatra's Avatar
+1
But why dont you just use the foglamp wiring thats already in the bumper so your not running wires back and forth
On the connector harness for the fog lamp
1 57 (BK) 20 Grounds
2 478 (TN-OG) 20 Fog lamp relay switched power
Old 08-27-2005, 09:21 AM
momalle1's Avatar
Old 08-27-2005, 09:26 AM
dean1614's Avatar
You could try something like this , I hope this helps, maybe some one in here has done this before
Old 08-27-2005, 10:54 AM
Colorado Osprey's Avatar
+1 dean1614, the only difference i did was add a switch next to the fuse, so I could turn them off independently.
if anyone is adding lights, make sure to check out your amp draw with everything on as to not overload your alternator and pull down the battery.
Good luck...................
Quick Reply: 2005 F150 Fog Lamp Wiring Diagram
