radio trim removal
Old 02-09-2008, 01:15 PM
05FONEFITY's Avatar
radio trim removal
i was wondering if anyone could tell me how to remove the trim around the radio and the actual radio removal itself i have 05 spercrew
Old 02-09-2008, 02:22 PM
econrad1980's Avatar
If it is anything like the 04 body style(new), all I did was use a flat screwdriver in between the trim and popped it out in all four corners. The radio is held in with four hex head screws. Simple procedure should take all of 10 minutes. Hope this helps......
Old 02-09-2008, 02:41 PM
BlueFlareside's Avatar
I have a Lariat with the center shifter and console. You did not say what model your is. To remove the entire trim piece I opened the ash tray door, pried very carefully at the bottom right and left edges of the trim, and then pulled from the bottom up. There are clips on the back of the trim to hold it in place. I think there were 3 or 4 clips on each side.
Old 02-09-2008, 03:22 PM
05FONEFITY's Avatar
thank you both of them worked just was a little carefull becase of the cold temps.
Old 02-19-2008, 12:32 AM
benkr16's Avatar
if you look in my gallery by clicking on the camera the right corner, go to he sirus sat hook up i did, it kinda explains on there. basically what the other guy said, about using the ash tray
Old 02-19-2008, 10:01 PM
StickyF250's Avatar
It's easy.. Don't use a screw driver!! Fast way to mess up the dash!
As explained above, access through the ashtray and just pry up, it's kinda tight but i will come off by hand..
Old 02-21-2008, 01:11 PM
street3285's Avatar
There is a thread somewhere in this forum that explains with pictures how to remove the radio bezel.
Old 02-21-2008, 05:57 PM
i found this one while looking for the same question......hope this helps...it helped me..
https://www.f150online.com/forums/sh...+radio+install
Quick Reply: radio trim removal
