10 LB. Pulley Questions?
I wanted to know who has ran a 10 lb pulley and what you though about it.
Also do any of you have one for a 2000 Lightning for sale?
gsuavy2002@yahoo.com
Peace, Suavy
Peace, Suavy
I seen a couple of adds for a 10 lb. pulley and I was wanting to find out wazz up????
I am adding these mods starting today...
Rods - Manley H-beam
Pistons - Manley forged pistons
Valves - Manley
Heads Ported, polished, and modified
Intake - port and polished 90 mm MAF
Supercharger, Magnum Power
Tranny - Factory Tech monster Box & 2400 stall
Traction - JLP lift bars
MT ET Streets 26 X 10 X 16
Front skinies 7 X 16
See you all at Super Stallions on 4-12-03
Peace, Suavy
Valves - Manley
Peace, Suavy
Valves - Manley
Peace, Suavy
Valves - Manley
Peace, Suavy
Whoa Suavy...that is one sweet mod list. With the built lower end, you can get crazy with the power adders. Don't forget the juice.
Rocks
I heard a few stories about them also.
However, after talking to a few engine builders who basicly told me the only issue they had is there is a lot to clean up on them size wise. Further, they thought they were good quality and durable pistons
What made them beter was Manley sponsered my internals.
Peace, Suavy
Peace, Suavy
I have a 10# pulley on my L. I haven't drove it yet cause I have a broken valve spring. It will be at JDM's the week after FFW Orlando and the springs will be changed out. Also a bigger heat exchanger will relace the stocker which I think is a MUST for a 10#. Will have some dyno #s around the 8th of March.
Later,
Justin
P.S. The 10# is so big that I had to tie the tranny cooler lines to the front sway bar for the pulley to clear. I will fix that properly when I get it back.
FYI, it takes a 70" belt for a 10# and stock upper
Later,
Justin
Originally posted by ib fast
"Got rods"
"Got rods"
I have run the 8# for 4000 miles, about 25 passes (7 in the 11s and the rest 12.0s) on a stock block.
Do I recommend it , NO. Is my 8# coming off , Eventually.
I always thought lower blower pulley size would blow the motor but my feelings have gone toward detenation a lot more as I have seen the stock eaton taken too its maximum and the motor is still alive.
Of course this is just my .02 cents.
VINNIE
