back window leaks!!!!!!!!
Old 08-22-2006, 01:28 AM
bone3349's Avatar
small but steady leak on the passenger side, back window of my 98 xcab f150. the glass is surrounded by molding and the seal looks recessed and out of reach. how do i get this fixed? thanks
Old 08-23-2006, 08:46 PM
davidshick2's Avatar
my friend had the same problem happen to him and we took it to the glass shop and they said it is common on 97-03 f-150 and they said the only way to repair ir is to replace the window I think you should be able to remove the back window andput a new seal on or use a silocone, at least I would try this first hope this helps
Old 08-23-2006, 09:54 PM
ncsufire's Avatar
The same thing happens on the 04-06 F150's. I think this is a design flaw as every time we have a steady rain and am driving on the road with my father-in-law or in my truck that we have this same leak.
Old 08-24-2006, 04:42 PM
ammoeater's Avatar
Join the club. My local stealership wants almost $500 for the "new and improved" window, seal and labor.
I've been putting it off for years, now I may as well replace the headliner too, since that is ruined. Oh yeah, high humidity in your truck cab does not mix well with leather seats, breaks them right down. Not to mention the musty smell...Thanks Ford for fixing a problem that has plagued these trucks for 10 years now. Everyone I know with a 97-2005 F150 with the slider window has or has had a leak.
Old 08-24-2006, 08:32 PM
Yankee7985's Avatar
The original window frames in these newer trucks were plastic, and they broke easily. You can get a new slider put in for about $ 150.00 by your local automotive glass shop.
Old 08-25-2006, 05:02 AM
BlacK50's Avatar
no problems with my f150 but ima look out for it damn im scared.... im poor
Old 08-26-2006, 10:33 AM
gold2000's Avatar
I have a 2000 F150 regcab and the same thing is happening to me. The seal is popped up a little on the passenger side, but the ever so little leak is on the drivers side.
Old 08-26-2006, 09:34 PM
machgt's Avatar
anybody know where to get some isobutyl type sealer for this? or should I just find some sort of sealant
Old 08-26-2006, 10:36 PM
Rockpick's Avatar
Moderator &
How To Fix A Leaky Rear Window
Search is your friend...
Old 08-27-2006, 01:03 AM
machgt's Avatar
I did a search, it didn't come up. I knew the thread was out there but I didn't have time to search long
Old 09-16-2006, 02:15 PM
MJB's Avatar
MJB
MJB is offline
Mine leaks too!
I am getting frustrated as all he** with this. Between the window leak and the darn manifold bolts breaking I am about ready to give up. I have only 60,000 miles on my 98 SC and I find it hard to believe I should be having such problems. That's just my 2 cents!
Old 09-21-2006, 10:13 PM
Shorty6318's Avatar
Exclamation Leaky Rear Window
Same problem as everyone else, I have a 1998 F-150 and fortunatly the only problem I have had with it is the rear window leaking. Its seems like the seal has pop out around the passenger rear window and thats where it is mostly leaking... I believe FORD should fix this problem since most of these year models have this problem?!?
Old 09-23-2006, 11:11 PM
altrdloc's Avatar
Ok guys, lemme see if I can help your leaky rear window problems.. I was having the oil changed in my 04 FX4 and told the guy at the dealer I was having the same problem. He told me that it was probably the center brake light on top. The gasket around the light was put on poorly and crushed down. Bear in mind he told me this before I even handed over the keys. The only problem is that it isn't covered by my waranty. it was a $35 light and you can't just by the gasket. but if it fixes my problem, then better than new window. So, I spent the money, went home removed the original light and sure enough he was right. Put the new light on and no more leaks. Not sure if this will fix all of your problems but maybe it will help a few. Hope I've saved someone from buying an new rear window.
Old 09-24-2006, 12:07 AM
brentcon01's Avatar
Help with window motor
Hi guys....They fixed my leaky window on my 04 FX4 with a new gasket too. However, mine has been leaking so long the motor is now broken from all the water. Ford wants $500 to fix it. I could replace the motor myself if I can figure out how to get to it. How do you get behind the seat back. It looks like it should tilt forward, but I can't find a latch. Can anyone help me? Many thanks, Brent.
Old 09-24-2006, 01:00 AM
Rockpick's Avatar
Moderator &
If it's on an late model, it's very unlikely that it's the 3rd brake light.
Quick Reply: back window leaks!!!!!!!!
