??? on 32 V engine
Old Feb 1, 2002 | 04:32 PM
11secL's Avatar
??? on 32 V engine
With the exception of the intake, would you see any problem with using a Navagator 32V engine and putting Lightning internals in it to do the 32V conversion? I know it would take some fine tuning, but what other major differences do the 2 engines have?
Old Feb 1, 2002 | 04:36 PM
Lightning Boy's Avatar
Physical size. The 4v head will make the blowe sit higher causeing hood clearance issues, unless you do some trick intake fabrication.
Old Feb 1, 2002 | 04:45 PM
11secL's Avatar
I am not going to use the stock blower on this engine. My main concern is with the bottom end of the engine. Thanks for the info though.
Old Feb 1, 2002 | 04:46 PM
Spade$'s Avatar
isn't the navigator head ALOT heavier? To the point that the HP and ft/lbs gain wouldn't help
Old Feb 1, 2002 | 05:02 PM
11secL's Avatar
It is heavier, but I don't think that it even comes close to not being worth the power. I have heard some pretty impressive gains from the 4v heads.
Old Feb 1, 2002 | 05:44 PM
mbrown's Avatar
4v mod motor mustangs are about to break into the 8's. I would say the extra weight would be no problem at all. There probably isnt 50 lbs. difference between the two sets. I dont know that for sure but its just a guess.
Old Feb 1, 2002 | 06:11 PM
11secL's Avatar
I see that Lightningtuner just posted his sales of the bottom end kit . Are you guys seeing where this is going right now. I want to take the navagator engine, bore it .30 and forge the hell out of all the internals (just like the kit lightningtuner is selling). I figure, for about 8k, you could have a fully forged 32V engine ready for a Twin Turbo setup. That would produce some major ponies!!! Does anyone for see a problem in doing this???
Old Feb 1, 2002 | 06:41 PM
mbrown's Avatar
Yes just one............I dont have the money to do this!
