Vacuum Line Help...
Vacuum Line Help...
I have a '01 Expy 4.6. This morning, I took out the battery so I could check for leaks in the black vacuum line that runs behind it. The vacuum line is plugged into some box that's attached to the battery cover. What the heck is this "box" used for? When I unplugged the vacuum line from it, it sounded like it relieved the pressure. Also, I sucked on the line to see if it held pressure and it does. Next, I tried blowing into the line. At first I couldn't but a second later it I was able to. It felt like something was temporarily blocking the line. I suspect that there is a check valve on this vacuum line because it holds vacuum but not pressure when you blow through. Anyone have any ideas? Any help is much appreciated.
Thanks,
Anthony
Thanks,
Anthony
on
I am afraid that it is a poor diagram but #7 is the A/C vacuum reservoir tank and #8 is the Engine vacuum reservoir. The L doesn't have a #6. Sorry about the confusion
JMC
This pic is of the Engine vacuum reservoir. It is behind the fender on the passenger side.
This pic is of the A/C and Aux. vacuum reservoire. The top reservoir is the A/C vacuum reservoire and the bottom is the aux. I beleive that only the 4x4s have the bottom one.
JMC
