Show 'Em Off!
#2748
Its only about 50 amps (if they're all 55W). The V8 trucks have a 130 amp alternator and a battery should have at minimum 660 cca. If there is anything to worry about, it should be the wiring.
#2755
#2756
o ok, thought it was something you swapped out. but i'm just so used to seeing the trim colors across the lower panels too i forgot that they came the way your truck is also..but i wanna say it was only FX4s....
#2757
#2758
