steering wheel swaps
search function didnt match anything when i used the word swap. but then just using steering wheel only produced one page with nothing related to my question.........so here goes.
i wanted to try and find a leather wrapped steering wheel to put into my truck. feels better & would be an improvement over my worn steering wheel now. but whenever i go to the junkyards, the same steering wheels i find are either the same condition as mine. or the leather ones are either the wrong color or really messed up & worn.
but as i was walking around the local junkyard today, i noticed a steering wheel in an explorer that was in perfect shape. and it looked like the one in my lightning. so i started to wonder if they were interchangeable? does anyone know?
my current steering wheel with a cover on it
and this is what the lightning wheel looks like
it looks identical to the one i saw in the explorer. but i dont want to spend about $75 on something that either wont work, or will take a lot of fabrication to make work. can anyone give any input?
Please don't forget to disconnect your negative battery terminal and wait a good 20 to 30 minutes before messing with the steering wheel. It's unlikely the airbag would deploy but it is better to be safe than sorry.
Let us know what you find out. I would like to swap my steering wheel too.
Mickey
Mickey
well, the explorer wheel would not work. harnesses are different. the one that clips into the clockspring appears like you cant even take it off...which in turn means the one that comes off on our trucks has nothing to plug into.
i ended up bringing my extra steering wheel into the yard to compare. if there was a way to get past the wiring issue, it will just bolt right up.
dont worry, i wont forget, lol. i had to take my steering wheel off my wrangler when i had a problem with the clockspring. had that thing off like 5 times in 2 days. but after the 1st 2 times i got smart & stopped setting the radio stations until i knew i was totally done, lol.
