Trick My Truck
Old 03-05-2010, 03:31 PM
Dinggus's Avatar
What kind of tools would I need? And Raptor, I'll be going to FedEx on Sunday to check the price.
  #467
Old 03-05-2010, 05:12 PM
fdimeroller's Avatar
lug wrench, floor jack, jackstands, ratchet, wrenches, probably an extended "breaker bar" for some of the tighter nuts on the rear, a good tool cabinet should handle it. i don't see it takin all day tho even for a beginner, the rear will be the easier/quicker part no doubt so start there.
  #468
Old 03-05-2010, 07:20 PM
Dinggus's Avatar
Okay. I'm picking up Jack stands and a trolley Jack and those tools at walmart, I can also do the back or front one day and do the other the next, right?
  #469
Old 03-05-2010, 09:03 PM
sure, depending on the difference in drop may have an alignment issue.. but it's definitely do-able. hooray for another do-it-yourselfer!!!!! woot!
  #470
Old 03-05-2010, 09:05 PM
jsvo5695's Avatar
It's pretty easy if you have the tools. But if you get stuck you can always get on here and ask q's!
  #471
Old 03-05-2010, 10:14 PM
1clean42's Avatar
Actually the rear is what took me the longest on my '02. The hangar rivets took forever to grind off! The front suspension was pretty easy to get apart and put back together.
  #472
Old 03-05-2010, 10:30 PM
thejake1989's Avatar
Yea and the front will be alot easier since you don't have to worry about it not BEng high enough off the ground to get it back together haha
  #473
Old 03-05-2010, 11:09 PM
Dinggus's Avatar
The kit will also come with instructions?
  #474
Old 03-05-2010, 11:21 PM
1clean42's Avatar
Mine did. I can't imagine one coming without them. At least from a brand-name product.
  #475
Old 03-05-2010, 11:29 PM
Dinggus's Avatar
Alright. I'll take the list of things and go buy them at walmart after I buy the kit. Probably going to cost me $100+ in equipment, ha.
  #476
Old 03-06-2010, 12:03 AM
It'll be worth it, not like they'll be one time uses. Not to mention the pleasure of having done it urself.
  #477
Old 03-06-2010, 03:38 AM
blackedoutV6's Avatar
A good day. Sunrise to sunset.
Atleast, especially for a first timer.
x2, i always start on the rear first when im dropping a truck. So that once its done i know that i only have to do the front real quick
But youll need a grinder/cutoff wheel definitely, noone mentioned that. And its a million times easier if you have an air chisle/hammer (or an electric one if the make it?). Also a big ole hammer, some pretty tall jack stands, and a socket set.
I did one hanger with just my grinder and a hammer and punch and it freaking sucked, took forever and i kept hitting my finger lol. I couldnt for the life of me punch out the rivets on the other side tho, so I ended up going and buying my air chisel, and im SO glad I did ha.
You can get a pretty good idea of what youll have to grind off if you look at where the front part of your leaf springs mount. The bracket is held on to the frame by 4 rivets, the heads are round and about the size of a quarter but a little thiker. The worst part is sqeezing the grinder up in there.
  #478
Old 03-06-2010, 04:21 AM
Raptor05121's Avatar
Awesome, but over here, all shipping places are closed on sundays
If you can get a measurement off the box and guesstimate the weight, just input the dimensions into any one of the Big 3's online shipping calculator
  #479
Old 03-06-2010, 04:50 AM
Dinggus's Avatar
A grinder? What kind? And I'll only have to grind on the front?
Will do, I got work in 30 minutes, so I'll have to do it when I get off.
  #480
Old 03-06-2010, 12:34 PM
any kind, i got a cheap one from like harbor freight like 6 years ago and its worked great lol.
youll have to grind the rivets off the hangers.
Quick Reply: Trick My Truck
