Trick My Truck
Old 06-11-2010, 10:38 PM
Dinggus's Avatar
I can't explain it, it has a push pin in the center, and once it's pulled up, you can pull the pin out.
  #857
Old 06-11-2010, 10:43 PM
five0merc's Avatar
You have to pry the whole thing out a little bit then push all but the center back in and then pull that canter pin out and then the rest will come out without a problem. That is how I got mine out. I have the same clips on some of my panels on my extended cab. Hope that helps.
  #858
Old 06-11-2010, 10:48 PM
thejake1989's Avatar
i just broke them haha
  #859
Old 06-11-2010, 11:32 PM
Dinggus's Avatar
Thanks! That is what I need to do, aren't they a PITA to get them back in?
  #860
Old 06-12-2010, 12:18 AM
five0merc's Avatar
you just put the main piece in then the center if i do remember. Or you can just buy new ones that aren't that way.
  #861
Old 06-12-2010, 12:20 AM
Dinggus's Avatar
What do you think would be easier to reinstall everything?
  #862
Old 06-12-2010, 12:34 AM
five0merc's Avatar
If you don't plan on taking the panels off again just buy the push in ones.
  #863
Old 06-12-2010, 01:15 AM
Dinggus's Avatar
Yeah, I plan on just putting this stuff on to make the music sound good and then that's it.
  #864
Old 06-12-2010, 12:10 PM
fdimeroller's Avatar
I thougt u had to push the middle pin in further to get em out iirc..? But idk had some on my last truck. But puttin em back in is definitely the easy part, like dude said above u jus put the big piece in then snap the middle pin in
  #865
Old 06-12-2010, 01:06 PM
Dinggus's Avatar
Took 3 weeks, but look what I just got!
Is that everything I need?
  #866
Old 06-12-2010, 06:10 PM
what temp u go with? & did u get bi-xenons?
  #867
Old 06-12-2010, 06:19 PM
Dinggus's Avatar
I believe I went with 35w 5000K and yes I did. Just trying to find a how-to install so I can put them in!
  #868
Old 06-12-2010, 06:24 PM
its pretty simple. should be all plug & play. you plug one of your headlights into the blue socket which is all the way on the right in picture. i choose my pass side cuz that's where the battery is. the power wire can connect to the battery. any grounds can be screwed into the first screw for the fender (in the hood jamb). light plugs into ballast, ballast gets power, & it all works . if those things in the boxes in the middle are the ballasts damn they're small. but light plugs into those, then they plug into the harness, the harness gets power from the headlight socket & battery. not sure how much that helps.
5000 should look good
  #869
Old 06-12-2010, 06:42 PM
Dinggus's Avatar
Found this nice picture:
In this thread: https://www.f150online.com/forums/ap...hid-kit-2.html
Time to get to work.
  #870
Old 06-12-2010, 08:00 PM
yep. its that easy
Quick Reply: Trick My Truck
