Trick My Truck
#1099
#1102
#1105
with that said a full tank with fuel stabilizer.. maybe put your truck on jack stands to avoid flat spots on the tires and im sure a fresh oil change wouldnt hurt either thats what i did with my mustang also maybe a cover if it is going to be outside to protect the paint... im sure there is other stuff you can do but thats all i kno im sure others will chime in
#1106
First and most importantly thank you for your service
#1108
Finally got around to adjusting my headlights, I can see so much better now, now looking passed my headlights and looking into the darkness, ha.
Before (I think my fogs were on):
Starting:
25ft low beams:
25ft low beams + fogs (fogs are higher, ha)
Low beams adjusted:
Low beams + Fogs:
High beams:
Back on the road:
I don't know if it was because it was the angle I had the camera at, but it doesn't look like you can see that well but it really is good.
Starting:
25ft low beams:
Low beams adjusted:
Low beams + Fogs:
High beams:
Back on the road:
