Trick My Truck
Old 12-28-2009 | 02:25 AM
Dinggus's Avatar
Well, I took the tailgate plastic part off, scrubbed it down with dawn dish soap and a green scuff pad. Sanded it down with 800 sand paper, then with 2000 sand paper, hosed it off, dried it, primer twice, and then sprayed a few coats on it. I don't know what 'light' coats mean, when I spray, I use half the can! So, this what happen, the paint ran in a few spots, and I accidentally ripped part of the paint at the bottom. So, now I'm just going to leave it alone, wake up tomorrow morning and spray a clear coat on it, and put it back on my truck, and then after work, start on the sides. Let me know what you think of this little spot, to me it actually looks good if you're not looking very up close at it.
The dark/light next to the chipped area, I believe that is just dew from outside, since its cold out.
  #107
Old 12-28-2009 | 07:51 PM
fdimeroller's Avatar
i remember on mythbusters they tested stuff over ur tag vs traffic cameras and nothing worked...
but anywho, is that a before or after picture? doesn't look very smooth..
when i did mine, i started with 80 grit, then went to 120, then 180, then wetsanded with 1000 then wetsand with 2000.
  #108
Old 12-28-2009 | 08:23 PM
Dinggus's Avatar
It's not smooth, still has those little bumps that came on it. I'm no professional, but it looks decent to me. I took pictures this morning and I'll post them up.
  #109
Old 12-28-2009 | 08:31 PM
o i thought u were tryna get it smooth
  #110
Old 12-28-2009 | 09:20 PM
Dinggus's Avatar
No I just wanted it painted. How do you apply light coats?
  #111
Old 12-29-2009 | 01:57 AM
well with spray paint, the easiest way to explain is...spray from a good distance 6-12". and don't go down the surface slowly, this lets the paint build up which causes the runs. so go down it in 1 smooth quick motion. not rapidly, but quickly.... get it? so instead of 1 thick coat, apply three light coats for example.
  #112
Old 12-29-2009 | 08:31 AM
Dinggus's Avatar
Alright thanks, I'll try it out. Is there a way to remove build up, or would I just have to start over?
  #113
Old 12-30-2009 | 01:04 PM
Dinggus's Avatar
Well, here's the new paint job. Not the best, but looks good to me.
Tailgate:
Left Side:
Right Side:
Next will be the step side and bumper plastic once I learn to take it off.
  #114
Old 12-30-2009 | 01:18 PM
That's a really clean truck man. A set of 20" L wheels would look awesome
  #115
Old 12-30-2009 | 03:18 PM
Dinggus's Avatar
Thanks! I'm looking for some good wheels, I found some all black with a thin red outline. L wheels are Lightning?
  #116
Old 12-30-2009 | 03:42 PM
Yup... classic looking wheels
  #117
Old 12-30-2009 | 04:02 PM
now the freshly painted pieces look out of place, guess it's time to do the rest of 'em 'eh???
  #118
Old 12-30-2009 | 06:56 PM
Dinggus's Avatar
I thought Lightning wheels came in 18".
  #119
Old 12-30-2009 | 07:04 PM
You can get replicas like Patman03sprcrw has
  #120
Old 12-30-2009 | 10:07 PM
Dinggus's Avatar
Thanks truckguy, I'll look into it. I'm kind of waiting due to the fact I got new tires like a month before I came home from Iraq. Can't have $1,000 of new tires go to waste.
