Vibration at 65mph
#31
#32
Thanks Jbrew... well everthing I read, even threads on here and the haynes manual said that when I fill the fluid up it should start to dribble out of the fill hole... so i imagined that even though this is the old fluid it should still be up to that level...am i wrong in thinking that?
Also with the rtv... I'm worried that when I put the cover back on... the rtv will squeeze into the diff. Also, i'm not using a gasket, so should I put the rtv on the cover, diff or both?
#34
Well the rain got the best of me today... so didn't get the fluid changed out. Glc, I called kragen and they can get the gasket for me in about an hour so from their warehouse. Do you have to use the rtv with the gasket? If this dang rain doesn't let up... I may just have to take the truck to the shop for the service... I hate paying to do things that I can do on my own, but I've got no garage and am at the mercy of mother nature right now...
Anybody know what a reasonable price to change it out would be ... if it comes to that...
Thanks again guys.
Thanks again guys.
#35
I'll go check, actually I think I have that online somewhere, I'll look, hangon.
Crap! Found a pick of what I use to fill them with lol.
Alright hangon, I'll find out from service.
#36
Yep that's what haynes says. pg 1-30... "fill the differential housing with the speciified lubricant until it's level with the bottom of the filler plug hole"....
is that too much fluid? I'll hold off on doing anything until i can check back with you guys for sure...
Thanks for looking Jbrew.
#37
#38
Hah! I was right lol.
Yea, that's the Ford service DVD for the 97-03 F150's. This has more weight than Haynes or Chilton's of course.
Thought I was going nuts for a minute. I did get them backwards though. The rear is a 1/4" Front is 3/8"
But all them say No Gasket. I'm not sure why, maybe they just won't last ?
___________________
If you have to take it somewhere, I wouldn't go anywhere but Ford. Unless you take it in somewhere and bring your own fluid and watch them. I'll see if I can find a price real quick.
#39
#40
#41
Thanks jbrew... sorry i didn't leave all the info. I have a 4x2 extra cab with the 6ft box... not a long box... not the four door. Not sure what the wheel base is. As far as tranny, not sure of the number... but I just had the tranny serviced and checked out at the ford dealer a couple weeks back, he said I have the heavy duty one... and everything checked out ok on it... And there is no leaking from the trans housing that the slip spline sets in to.... hope thats all the info you need. I know its really a pretty simple service... but anything you can get at the the dealer for less than a hundred bucks ain't too bad, right? Most of the time i go to the dealer I feel like I'm paying a $100 cover charge just to walk in the door!!!
And I'm guessing that the haynes just words it that way for the layman... really it is a bit strange that ford would give the measurement that way seeing that when you fill it its a hole the size of a quarter that is pitch black
... really it seems that it would be a pita to get it exactly 1/4 inch below the hole.
#42
There was one TSB (TechnicalServiceBulletin ) that described a vibration issue, but it wasn't specific to speed. A break down of fluid vibration, specially in the 9.75's (which you have) is specific to 55-65mph +. There's been quite a few posts in the past in the powertrain forum on the site -
https://www.f150online.com/forums/other-powertrain-15/
The easiest way to fill is pre-measure in liters/pints, whatever your comfortable with, then squeeze it in their. You will see what I mean by squeeze when you fill it lol. Anyway, should come out perfect because when you pop the rear cover, you can drain it completely and even wipe out the bottom. Just get it as close as you can, at least now you know where it's gottuh be.
BTW - You'll need a putty knife as well, - to slowly pry the rear cover off to drain.
#43
If you use a gasket, put a very thin coat of RTV on both sides of the gasket to stick it in place while you are rebolting the cover. It's a lot less time consuming than using just RTV, which requires a setup time before bolting the cover on. Sorry, I just don't trust using RTV only on that thing.
#44
