Horn not working...
Old 05-27-2010 | 12:55 PM
Toyz's Avatar
Originally Posted by killer48
I had the same problem, fixed it with a new clock spring
That sounds plausible.
Old 05-27-2010 | 03:06 PM
jbrew's Avatar
Sounds good to me.
Old 05-28-2010 | 12:26 AM
fordmatt21's Avatar
Just tried the cruise control for the first time since getting the recall done, turns out it doesn't work. Looks like it's the clockspring, any tips on replacing it? Messing around with air bags makes me a little nervous but I'm going to give this one a shot myself I think.
Old 05-28-2010 | 05:44 AM
jbrew's Avatar
From Ford, it was written exactly this way -
CLOCK SPRING/AIRBAG
TO AVOID ACCIDENTAL DEPLOYMENT AND POSSIBLE PERSONAL INJURY, THE BACKUP POWER SUPPLY MUST BE DEPLETED BEFORE REPAIRING OR REPLACING ANY AIR BAG SUPPLEMENTAL RESTRAINT SYSTEM (SRS) COMPONENTS. TO DEPLETE THE BACKUP POWER SUPPLY ENERGY, DISCONNECT THE BATTERY GROUND CABLE AND WAIT ONE MINUTE. BE SURE TO DISCONNECT AUXILIARY BATTERIES AND POWER SUPPLIES (IF SO EQUIPPED).
__________________________________________________ ________
So just disconnect the battery. If paranoid, -after your battery is disconnected, pull your PCM fuses, flicker your heads and brights. Wait 30 minutes and there will be NO power period in KeepAliveMemory (KAM).
__________________________________________________ __________
#1 is what your after I believe.
BTW - There's just one #26 and 54. I messed that up somehow ( :
Old 06-05-2010 | 03:09 PM
chiaronate's Avatar
Wow look at this I'm getting in on a current topic. I'm also having issues with the horn, but it's staying stuck on. The airbag light isn't on, and the cruise control works before I take the horn fuse out. I took off the airbag cover, but I don't know what to look for in there..I read someplace about the foam padding getting worn out between the horn contacts? I didn't see any padding in there, could that be the problem? Does anyone know where I can find a picture of the horn contacts? I don't care much about the horn, I would just like to use my cruise control lol.
Old 06-05-2010 | 11:25 PM
chiaronate's Avatar
I think I found the problem. I did some searching on the internet, and it turns out someone was having the same issue when he did what I did, which was remove the steering wheel emblem. When he put it back in, the tabs on the emblem "dimpled" the electronic horn pad, completing the circuit and making it sound continuously. I started having this issue not too long after I did this, so it looks like this is the problem. Does anyone know where I can get a replacement pad cheap?
Old 06-06-2010 | 12:37 AM
a930rocket's Avatar
What's a "clock spring"? And do you have to disassemble the the entire steering column in order to replace the air bag sliding contact".
I might have to live with only the high note before I disassemble the steering column.
Old 06-06-2010 | 12:49 AM
chiaronate's Avatar
A clock spring allows turning of the steering wheel without wires getting tangled. From what I've been able to find, a sliding contact is just another name for a clock spring..it is located just beneath the steering wheel, so you will have to remove the steering wheel to replace the clock spring. I've also seen written somewhere that you can damage the steering shaft if you don't use a steering wheel puller to remove the steering wheel.
Old 06-07-2010 | 06:40 PM
chiaronate's Avatar
Well I fixed my horn issue by cutting out the center section of the horn pad and placing a piece of plastic in, and taping it on with electrical tape. The dealership only sells it as part of the several hundred dollar airbag unit, it's pretty disgusting that Ford would do that to its customers.
Old 06-07-2010 | 09:07 PM
Red02FX4's Avatar
Cutting out the plastic cover to the airbag can be hazardous to your health. I would like to see a pic of this one
Old 06-07-2010 | 09:21 PM
chiaronate's Avatar
I didn't cut the airbag cover, just the horn pad. Here is a link to where I got the idea from. http://www.ford-trucks.com/forums/sh...73#post8976373
Old 07-07-2010 | 01:38 PM
MITCHYKINS's Avatar
if the air bag goes off anything on the cover or just below is coming at your face at over the speed of sound. it's gonna hurt right away
Mitch
Old 07-08-2010 | 09:20 AM
why do yall need a horn just use your middle finger its alot more affective
Quick Reply: Horn not working...
