replacing o2 sensor
Having bad experience with the Bosch on other vehicles and the parts guy telling me I'd need to modify the harness for it to work I purchased a denso replacement for my failed bank1 sensor.
4wd150 - I'd wait for an SES code before replacing them. I'll let you know in a few days if the one I pull out looks like it was original (truck has 236K miles)
The only place I saw something with a Motorcraft name on it was actually an ACDelco.
There's Green, Blue and White Connectors. Some you have to shave the **** off in order to connect. This is normal. Also upstream and downstream O2 sensors are identical and interchangeable. Same deal, you may have to shave that **** off the connector.
Just though you guys might want to know.
1997 ford 150, 5.4 trouble code p0141
1997 ford 150, 5.4 trouble code p0141.The code was followed by Bank 1 Sensor 2. Replaced Bank 1 Sensor 2 after 2 days of penetrating oil and patience.To my dimise still runnining rough or stumbling sometimes. Retested after instulation of Oxygen Sensor and still read p0141 Bank 1 Sensor 2. Part store gave me the long list of possible causes (EGR module, HO2S, PCM ect.). They also gave me the reported fixes. Is there a possibility that sensor 1 could be the problem ? since it is on the same side of exhaust. My understanding that Bank 1 Sensor 1 has been problamatic in some vehicles also I noted that under the reported fixes of my vehicle that Bank 1 , Sensor 1 is the only sensor that has not been replaced on this vehicle. Respectfully, Dwayne
Sensor
Yes replaced the downstream on passengers side. Code definition = Downstream heated oxygen sensor heater htr 12 circuit malfunction Bank one. after replacing sensor tested same code. I was hoping all I had to do is replace bank 1 sensor 1 but seems to be a bigger issue, maybe By the way thanks for corresponding. hopefully we can resolve this issue
Yes, Identical sensors, - different harness length and slightly different connector. But both sensors will connect to up and downstream vehicle harness connectors.
The heaters (*both white wires) and signal + ground all have to be spotless inside the connectors in order for a well enough connection. Currently, one or both of your white wires have an issue.
You need to inspect the connecters for corrosion and/or foreign matter. This connecter is probably the pickiest, as far as being clean to function properly.
Use something that's plastic safe to clean/flush the connector. Perhaps mineral spirits, denatured alcohol or whatnot. A small brush and compressed air to assist would be a big help.
When it comes to the downstream, it usually always the connector. Somethings up with your white wires, need to investigate @ the vehicle side O2 connector. Make sure you clean BOTH connections at this point, before reconnect.
Disconnect the battery before preforming this one. -Definitely.
For what it's worth, here is a write up with pics I did a few years ago on how to swap out the O2 sensors.
https://www.f150online.com/forums/ar...r-install.html
