lower rear end help
Yeah,
theres no 2" block in a 2wd truck.
You just need 2" drop shackles.
Here ya go.
http://www.lightningforceperformance..._/_Harley.html
Phil
Here ya go.
Phil
thanks alot phill6608 it seems you are one in a few in here that really knows how to help someone but i also have this problem i am stuck so i broke it down for all the men in here that tend to halfway read or understand how to answer a question in hre and here it goes>>>>>>>>>>ok here is what i got the 1998 5.4 and 1998 4.6 for me to go to the 5.4 from 4.6 i got 5.4 wire harness 5.4 comp trans and 5.4 engine i am ready to swap from the 4.6 ok i take 4.6 trans engine comp wire harness out and replace it with 5.4 wire harness trans engine and comp am i leaving anything out will i have to have the dash wire harness also i mean if the 5.4 was a 1998 model f150 just like mine i guess my question is will i have to swap the dash wire harness also its a tight super bowl game getting good got more beers to drink i need all yalls help
As long as your current trans is still good you just need the 5.4 motor and the 5.4 wire-harness. Some guys even run the 5.4 with the 4.6 wire-harness.
You can get a tune for the computer thats already in the truck to run the 5.4
Actually, the 5.4 will run on the 4.6 tune, but it will run better with a tune for the 5.4
If your going to swap it all,(motor,trany and computer) then yes.You have it right.
Both the 4.6 and 5.4 have a 4r70 trany.
Phil
Phil
:c ool: i explained it so the next thing i would have done was draw the slow people a picture lol i guess the guilty ones will get offended and start lashing out at you it is right the first to speak up are the guilty ones hahahahahah
