Custom sub boxes *extended cab only*
#33
#35
i like that, my problem is that... i have my amp mounted in the middle on the hump.. i have only one 10 inch pioneer thousand watt sub, and i also have speaker boxes id like to have under there haha, but if i could angle the box in those spots it would fit perfect, where is your amp??
#39
#40
#41
#42
The only tool you need to make a square/rectangle sub box is a jig saw and a drill. Lowes will cut the sheet of MDF as many times as you want, as long as they are straight lines.
#45
