New HID
Old 07-13-2011 | 07:52 PM
MJMoog34's Avatar
New HID
So i just go a set of hi/low 8000k HID and i think there is a problem. I only have two lights, two ballast, and the relay that hooks up to he battery. The hook up diagram shows that i should have some other hi/low control thing? any help please???
Old 07-13-2011 | 08:45 PM
pizzaman711's Avatar
The relay is whats used for the hi/lo setting.
Old 07-13-2011 | 08:46 PM
MJMoog34's Avatar
How is it wired? because i hooked the relay up to the battery and if i hook the relay to the ballast then the headlight only hooks up to the factory plug?
Old 07-13-2011 | 09:04 PM
When you hook the ballast to the factory headlight plug you should have three wires plugged in on the ballast side if I remember correct the middle is the hi-beam signal, and the outside is ground and low beam signal. I don't remember the color codes though.
Old 07-14-2011 | 04:20 PM
MJMoog34's Avatar
Well i got it hooked up thanks! haha they are really nice! i got 8000k and they arent too blue and really arent too bright and didnt have anybody flash me during my 2 hour drive round town last night!
Old 07-15-2011 | 03:03 AM
Raptor05121's Avatar
Just because you didn't get flashed doesn't mean its safe. One of these nights I'm going to record a test I did. I kept my 50W bi-xenon projectors pushing over EIGHT THOUSAND LUMENS on high beam and out of ~30 cars I passed, I only got flashed ONCE.
tl;dr- Getting flashed isnt a measure of glare. See below (both are jokes referring to the owner of the truck in the pic)
Old 07-15-2011 | 02:01 PM
MJMoog34's Avatar
Well im going to retrofit L headlights soon so taht should help right?
Old 07-15-2011 | 02:29 PM
Buxton91's Avatar
If they are in your factory lenses then I would take them out until you get the retrofit done. Those things probably have insane glare!
Old 07-15-2011 | 02:45 PM
MJMoog34's Avatar
Ok! haha thanks for the advice. And how hard is it to retrofit? Jw cuz i know how but is it time consuming or just straight up hard?
Old 07-15-2011 | 03:41 PM
L headlights is a strait swap, I think there referring to retrofitting projectors in which isn't too hard just takes time and patience.
Old 07-15-2011 | 03:46 PM
MJMoog34's Avatar
Any advice on good retrofits or even aftermarket projector heads?
Old 07-15-2011 | 04:19 PM
https://www.f150online.com/forums/il...t-members.html
Look through there, and a lot of people get there stuff from theretrofitsource. pm raptor, he posted a little ways up, he could give you good advice.
Old 07-15-2011 | 09:07 PM
for a nominal fee
haha JK.
go check out www.theretrofitsource.com
Old 07-15-2011 | 09:10 PM
Haha I figured you'd be the best person to ask when it comes to things like this.
I'll let you decide that one. I don't like to toot my own horn
Quick Reply: New HID
