Did the dealer screw me??
Old 10-06-2011, 02:27 PM
glc is online now
Sounds like your dealer charges $125 an hour and you got bent over on the labor too.
Old 10-06-2011, 02:50 PM
sniknah's Avatar
I didn't even get a kiss....
Old 10-06-2011, 03:40 PM
Midnightride42's Avatar
Was your entire sending unit bad? Or just he pump. If it was just the pump shouldn't they have replaced just that vs the entire thing? Also, did they replace your fuel tank straps under the recall?
If not, I'd be complaining because you'll have to take time out of you day to take it back if your getting it fixed under the recall.
Old 10-06-2011, 03:42 PM
dasher108's Avatar
Originally Posted by rednutbow
did they supply lube with that price?!
I did not know you had to lube a fuel pump?
Old 10-06-2011, 04:34 PM
Old 10-06-2011, 05:37 PM
rednutbow's Avatar
You have never changed the lube on your fuel pump?!
Old 10-06-2011, 06:19 PM
alex7191's Avatar
my girlfriend had the fuel pump on her volvo changed at the ford dealership for 800.. but volvo paid for the pump
Old 10-06-2011, 06:56 PM
sniknah's Avatar
They just said the pump was bad, and then replaced the whole esembly, what a difference it made though...fires like "bam"
Old 10-06-2011, 07:00 PM
Alex_4.2L's Avatar
yeah you got screwed
Old 10-06-2011, 08:44 PM
Uncle Jesse's Avatar
I got mine done for 700 at Pep Boys. My fuel pump went out pretty much all of a sudden. I have had some work done at that shop before so I trusted them. I live in an apartment so didn't have a lot of options.
Old 10-06-2011, 09:49 PM
FWIW on a supercrew you can not simply pull the bed off, the cab is too long, and you must drop the tank out
Old 10-06-2011, 10:07 PM
Raptor05121's Avatar
So I guess you're between a rock and a hard place them?
Old 10-06-2011, 10:12 PM
wat?
Old 10-07-2011, 01:28 AM
jbrew's Avatar
Originally Posted by mxmike800
Jesus, ida pulled the bed, like 6 bolts lifts off with 2 people and theres a main connect in the back for unplugging everything.
No, even with the manpower or lift and new hardware for what gets broken, it's still much much slower. This being the better option is one of those myths that go around the internet like the plague. If your interests involve auto repair long enough, you'll eventually rid yourself of this misconception, in time.
Old 10-07-2011, 01:36 AM
jbrew's Avatar
Originally Posted by 88racing
The dealers around here will round the diagnostic 0.5hr up to 1.0hr and the 2.2hr up to 3.0hr so then the total will be 4.0hr.......
Right, that's what I've been told before as-well and makes sense according to cost.
I asked around, this procedure usually runs $850 on average. Supposedly, the Ford Pumps or the replacements they use aren't cheap and should last the life of the vehicle. The original pumps have been much improved.
Quick Reply: Did the dealer screw me??
