2wd supercrew leveled
do i need to say it in any other language?
he wont need block or an aal with a 2 inch spacer
maybe you needed the block cause your garden hose added an extra inch
to drive my point with more FACTS :
http://www.lmctruck.com/icatalog/fe/full.aspx?Page=140
what are you talking about ?!?!?!?!?!?! the stock 2wd 1997-2003 f150 had a stock rake of 2" (two inches, zwei Zoll, два дюйма, dos pulgadas)
Im just very hurt by the way you and some others are treating me. Im a very sensitive man and hurt very easily. i would only want to make friends here. and try to fit in as best as i can
im sorry just dont like miss information getting trown around,
on my 1999 2wd f150, had a 2 inch rake
my friends 1998 2wd f150 had 2 inch rake
my cousins 2wd 2000 f150 has a 2" rake and is still 100% stock hes scared to pump gas in the damn thing.
im just saying
maybe by some chance your 2002 2wd f150 only had a 1 inch rake
best thing to do is measure from the highest point on the fender wells front and rear and check the differance, as mine sits right this second in the lot, the back end sits 1 inch taller then the front you cant tell from a distance but sure as hell a ruler can.
im just saying
Ok im sorry if im misinformed. But the fact is the 2wd stock is incredibly low. and it is basically level i consider 1 - 1 1/2'' level . So hed be doing good to raise front and back as much as possible (suspension lift) otherwise dont bother with a lvl kit imo. its just not worth it it will still be incredibly low. even spindle lift would be better.
My truck, as I bought it, before spacers, new paint, FX4 rims/tires, stock front and rear height :
My truck, two inch coil spacers, stock rear height :
