Not sure if this is fixable...
not sure if this helps but it looks like an 02 sensor issue http://www.casc.on.ca/forums/showthread.php?t=16221
http://www.obd-codes.com/trouble_codes/ford/p1151.php
found this hopefully one of them is the answer!
The discription as given is BANK 2, SENSOR 1 or drivers side upstream (nearest engine).
What's the code? Likely a 174 code.
This is why you don't know what to do with it.
If the reader/scanner only gives you the OX sensor location, get another reader that reads P code numbers.
Then you get the Ford code discription.
After that, you have places to look for the issue that is causing the code to be set. Hint, it says 'lean'. As in air leak at some point in the intake.
Said another way, it likely is not the sensor that is at fault but the only way the system has to tell there is a problem at some 'other point' in the induction system.
It's not as simple as your thinking.
Good luck.
Good luck.
You really need to get the p code for us to help you. Could be a bad sensor or it could be a vacuum leak causing the lean condition infact thats probably the case but I could tell for sure if you posted the correct code. Autozone and other parts stores will pull them for free. Get the EXACT p-xxxx code and bring it back to this thread.
