old problem went away and now came back. . . .misses really bad for about 20 sec
OK, so back febuary my truck developed a weird issue. The truck would start fine and so I would back out of my driveway and about 10 seconds down the road it will miss very bad and have almost no power for about 20 seconds BUT if I went WOT it would clear up in about 1 second and be fine for the rest of my drive. It would do it every single time I started the truck whether it was hot or cold. I just finished swapping in a newer motor(not for that reason) and the problem went away. . . . . for about a week then came back. I removed the throttle body spacer and no change. I had a whole other throttle body setup from the other motor so I swapped it and no difference and it almost seemed worse but I cant be certain. All plugs are brand new, wires are under a year old, and I am running a superchips programmer. It kind of seems like the comp has to re-learn every single time I turn the truck on. Yes I do have 2 codes. One is bank 1 lean and lack of 02 switch but I have always had these codes even when it ran good. I really have no idea anymore. I ran the scanner while running my truck but I couldnt decipher anything from it. Coil breaking down maybe? Its just really wierd that it did it before the swap then it stopped when I put the new motor in then started again a week later. I literally get about 20 seconds of the truck running like complete crap then it smoothes out and runs like a top.
You should also return the tune to stock till you get this figured out.
If you are running a K&N, when was the last time you cleaned the MAF?
Starting to hate this truck. I have been having to fix or replace parts every single week. K&N yes and when I swapped the motor I cleaned the maf and throttle body. I actually just put a new o2 on the drivers side upstream and the missing went away but now I have bank 1 lean and bank 2 lean codes :s. Im going to go over all my vacuum lines first.
