F150 Heat of the Day wont start
Haya Guys
i have a f150 01 5.4 supercab
at 2pm when i get back to work and turn off the engine
4 hours later in the heat of the day
my engine wont start engine cycles but dosent fire takes
several attempts to get her started
after it starts it is sluggish and then the idle revs then drops revs then stalls
after i start it back up it's fine
intill the next day
Any thought Any help much thanks
I have Changed
Fuel Filter
Air Filter
Fuel Pressure Regulator
cleaned throttle body
intill the next day
I have Changed
Fuel Filter
Air Filter
grandma's 97 F150 with the 4.6 engine was doing the same thing, it only did the it sluggish thing once but when the outside temp went up and you did some stop and go errands, you could count on being stranded or at least sitting for 15 minutes to a half hour. Then it got to the point where when we had a really hot day (105 and up) it wouldn't start at all. I borrowed a fuel pressure testing kit from Oreilly's and found there was no pressure. I also crawled under and had Nana turn the key to the on position so I could hear the pump and it wasn't running. I had a couple of guys recommend Carter as a good replacement and I found one at rockauto.com for $142 (the Ford dealer wanted $425 plus $225 labor). Ordered it at 2PM one day and it was at the Post Office before noon the next day! I slid the bed back a couple of feet, my shoulders are not up to overhead work. It was time consuming but an easy job.
