Clutch Replacement time?
128k miles, 4.2 5-speed.
Recently,
Pushing my pedal down, the first half has no pressure, still catches though. Haven't noticed slipping. Checked all fluids, seems good. Since I've owned the truck she "hops" a bit letting out the clutch smoothly rather than abruptly, not sure if this is a truck thing. Always owned VW's and Hondas in the past. I let out the clutch smoothly and never had hopping.
I went to Ford and asked for pricing on a diagnostic and reman clutch. Diagnostic was around $200 and full reman clutch was $1100. This sounds REALLY pricey to me for a 14 year old truck. Suggestions?
Recently,
I'm hoping it's the master cylinder. Will have it looked at monday. I had a mechanic suggest the hopping was a warped flywheel right after I got the truck. I got so used to it I don't even remember if the hopping is worse when it's cold or not. lol But I've noticed it coming off exits on long trips too.
Well. It was the clutch as a whole. Needing to be replaced. Problem, on this particular year and wheelbase, they have to drop the torsion bars to get the transfer case and tranny out. The problem is, the torsion bars are so rusted out, they can't get them off. Hmmm.... How much to replace torsion bars? And also, I've dropped over $3k on this truck. Got it for $4k. Should i keep at it? Other than the clutch i don't know what else can go wrong rust related outside the cab corners. I know now if I go to sell it, i still won't get more than $4k. That's pushing it in the area I'm in, and with a bad clutch, that's a loooot less. I'm starting to think i may have blown about $5k at a time i didn't need to blow $5k. :-(
Replaced clutch on my 98 F150 last year, big job, and I posted a few comments, but don't recall how to find them. As for torsion bar removal, I found rearward tension (come-along) on crossmember, while BFH finally worked well. Clutch ($400), Flywheel resurface ($40), Slave Cylinder ($80), Miscellaneous parts ($50), Gas to shop ($150)
