98 F150 4x4 with 4.2 motor, fuel problem
Need a little help guys. I can cold start my 98 f150 with the 4.2 and it runs fine. After you drive it for a while and turn it off and try to restart it, it starts then dies, it will do this until you rev up the motor to keep it running. I have to drop in gear and get going down the road and then it smooths out and runs fine. I had a mech check the fuel pressure at the rail and it was 19 psi. The book says it is suppose to be 35psi. He said my fuel pump was bad. I installed a fuel pump and it is still doing the same thing yet. Any ideas what to check now? Thanks
