2000 F150 needs to pass emissions help
I just recently put a new timing chain kit in my F150 and now I am getting 3 codes that are keeping me from passing emissions test.please help if you have any suggestion also there is a wire on the same harness going to the power steering pump that i dont think plugs to anything i have the one on the pump but the other one is about 6in long and i cant find where it plugs too or if its just a diagnostic connector below are my codes P0156 o2 sensor malfunction (bank 1 Sensor 2) p0136 o2 sensor malfunction (bank 1 sensor 2) p1131 manufacturer specific code Thanks in advance for any help you can give ! by the way its a 2000 f150 4.6 romeo
P0136 02 Sensor Circuit Malfunction (Bank I Sensor 2)
http://www.obd-codes.com/p0136
P0156 02 Sensor Circuit Malfunction (Bank 2 Sensor 2)
http://www.obd-codes.com/p0156
P1131 Lack of Upstream Heated Oxygen Sensor Switch - Sensor Indicates Lean - Bank No. 1
Bank 1 is passenger side, bank 2 is driver's side, sensor 1 is upstream (before the cats), sensor 2 is downstream (after the cats).
