Are the hoses sold today as good as the OE hoses? When Autozone and Advance Auto came to my area several decades ago, their hoses were crap and would fail within a year. My 02 is still running the OE hoses.
My 02 manual said check the color of the coolant. If it is green use the old style coolant that has to be changed more often. Mine is green so I'm using the old style coolant that is green. If it isn't green use the long life coolant. I don't think it is okay to mix them.
You can use the Deere stuff, but only if you do a complete flush. The hard part is going to be doing a complete drain including the block after you flush it. If you used concentrated instead of premix, this wouldn't be an issue. The Deere coolant is top quality.
