Lock rear end while in 2wd??
The conventional wisdom you keep referring to comes from a time when 4WD trucks had straight axles and 4 leaf springs. The problems were more associated with the suspension than the drivetrain. Again, full time 4WD has been around for a long time and this has nothing to do with AWD. You are right, they are different. You are also right that it's not a good idea to unnecessarily drive on pavement in 4WD. BUT, with common sense it's not the killer it once was.
AS I said though, trust yourself and do what is best for you. You can't go wrong that way.
Yup, may not have the same problems as the old systems but page 178 in 02 owner Manuel says not to use on dry hard surfaces or turning..
Me. The drive train is only so strong and not meant for heavy pulling stumps, other heavy jobs etc.
Why debate it, bring other systems into this and throw common sense out the window.
The driver side front CV axle is coupled with a Splined sleeve to self lock the front through the spider gears. If one wheel loses traction the other still won't pull, sort of a semi lock situation.
If both tires have the same traction in a turn, they fight each other for who has the most traction. (skitter and shake) occurs.
This is hard on the CV joints and driveline all the way back to the transfer case drive and steering becomes difficult..
It's unfortunate but it was necessary that Ford had to remove the ability to adjust the speed and weight of electronic steering in 2014. There were just too many yahoo's that thought they could turn there truck in to pre-runners or trophy trucks with some steering adjustments. Not only was this nonsense to believe it made their trucks less than what they were.
What's actually going on with your concerns is force vectoring in opposition to stress tensors which are measured in units of area and units of time along with the common variable of weight bias in relation to acceleration (which also means deceleration.) I encourage you to learn everything you can about the relationship between the chassis, suspension and drivetrain. If you do, you will live a very comfortable life.
I'm also encouraged by being challenged over this. Thank you.
The following users liked this post:
