99 4.6 drop in 02
99 4.6 drop in 02
Picked up an non rusted 02 with a blown engine. So instead of buying a new one, I picked up a low mileage 99 donor. It has the same 4.6 in. I thought. The donor has coil packs. Mine had COP. Is this possible to swap easily? Or did I just waste my time and money? Any help or insight would be helpful
Pull the blown engine, pull the heads and see if they are any good. If they are, use those heads on the 99 engine along with the manifolds. The only downside is you will have a higher compression ratio which may require premium fuel.
For the sensors, you are going to have to do a side by side comparison.
