4.6 2v triton Power gains + using 2v GT parts compatible?
An engine is an air pump basically. More displacement will pump more air. I think the 5.4 has the same size pistons with a half inch longer stroke. Probably 20% more power and torque. More power is obtained by pumping more air and fine tuning the engine. A programmer will fine tune the engine for a little more power. Changing the rear diff gear to a higher numerical ratio will put the power you have to the ground quicker.
The following users liked this post:
