Clicking in center console
Has anyone else noticed that when you depress the brake pedal while the truck is in park that you can hear a click in the center console? It doesn't happen once the truck is in gear. I can't say for sure that it's always been there as I usually have the radio on before I put it in gear. I have about 2500 miles on the truck so far. It's a Lariat SCrew with center flow through console and 4x4.
Clicking noise in Console
I have an '04 Lariat SuperCrew 4x2 with the flow though console as well. I have heard the same thing. To me, it sounds as if it is an electronic solenoid releasing an electronic lock on the shifter. As you know, the shifter won't move until the brake pedal is depressed. I think when you depress the brake pedal, it releases an electronic lock to allow the shifter to then move. That's my take. Chris
