tonneau covers
The Jason Cover... was right at 1k installed with the carpet headliner and keyless entry and tailgate gasket... (all of which were extras so can be cheaper)
I'm not sure how easy it would be to pop on and off... I'm only about 5'9" tall so if I have to haul a bunch of stuff or something big enough that I'd need to remove it I decided that it would probably be in my best intrest that I'd rent a trailer or something.... (I also have the real short bed) the Large trunk suits my typical needs best.... However I am impressed with it's water proofing and such.. I had it washed the other day to check it out.. well turned out I had to put something back there before getting it washed and one of the latches didn't get tightened enough and had slipped down so it wouldn't latch back (until I was able to readjust) so I had them wash it anyway.... even unlatched on one side no leaks... I was shocked... my parents Lo-rider on the King Ranch leaks quiet a bit up by the hinges...and their lowrider one doesn't have the carpet liner, a light, or keyless entry and costed the same amount.. So I think the Jason ones are a little bit better value.. both seem to have real good fiberglass work.
The grill guard was right at 500 installed... and so far it has the best look in my oppinion... I like how it is contoured to the body more than most of them.. and with 2 little latches it flips forward 2-3 inches and allows the hood to raise and lower clearing the guard...
