Transmission jerking?
Are you certain it is the transmission? I thought my 2001 had a failing transmission. It had a slight intermittent jerk when going up a slight grade and under very moderate acceleration. Turned out to be an engine cylinder misfire. I replaced all of the spark plugs and the problem went away. I believe others have experienced coil problems.
I have the exact same problem. Also the other day I took off from a dead stop and the truck hesitated badly and the CEL was blinking. I pulled over and the light turned off. The owners manual says a blinking CEL indicates a misfire. Been fine since but it does still jerk like when going up a hill. I thought it might me the tranny but maybe not. I have also had 4 leaking injectors replaced. I wonder if I have coil problems too. I only 3700 miles on this pig. What a joke.
