gettin the oil filter off
man that sucker was on there tight!!!
its not in a bad spot.... just installed WAY too tight!
tried for 1.5 hours to no avail. socket type wrench just slipped and i broke my strap wrench. once the can started to deform i just took it to the dealer.
they charged me $9
$6 for the filter and
$3 to get the old one off (took the guy 20 minutes)
anybody else have this problem?
they charged me $9
Mine was unusually tight...and others on here have said the same. I don't have that problem anymore, now that I change it myself (after getting the factory filter off). I use the socket type filter tool. Fits over the end. I had a much better tool that will NOT strip...it'll destroy the filter before anything else...but it was too small...won't fit this fat filter.
Mine was on really tight also.... I had my son (stronger than me) up top, and I was under with a clamp type wrench. He used his hands and I used the wrench... it finally started to move... we turned about an eigth of an inch at a time, readjusting the wrench as we went so it wouldn't collapse the filter... it finally broke loose. I don't understand why it has to be installed so tight at the factory.
Snapon has a oil filter wrench that works for the impossible filters. The harder you turn the harder it grabs. To see it go to snapon.com and do a search for oil filter wrenches. To find it quick put the stock no. FWA62121 in the search block. I had a 2001 that a ford gorilla put the filter on. By the time I got it off there was no way you could tell what it was. I saw one of these wrenches on the truck and had to have it.
Mine was tight also. I don't know why they put all those ft/lbs
on that small filter. Anyway, I got mine off by first taking the
the little small drip pan under the filter out of the way(this won't go back on). Then, I stuck a screwdriver through the filter.(this is messy). I let it drain for a while, then push the screwdriver all the way through to the other side and using the end as handles I finally got it to turn. Put on new filter hand tight only so I won't
have to go through this bulls#$@! again. No drips. Will be easy to get off next time. I always change my own oil. I don't trust those kids at the neighborhood oil change units(jiffy,etc.)making minimum wage tending to my $30,000 truck and dealers are too
expensive. JMO.
2004 Screw Lariat
expensive. JMO.
2004 Screw Lariat
Originally posted by Grimalkin
Zacky...I tried that and ended up with oil all over the engine compartment and undercarriage. I noticed that the oil pressure guage was reading -0-. Adding additional oil didn't seem to help. Do I have a problem?
