Outside air temp indicator
I am looking for some input on the outside air temp indicator. I have an 04 SCREW with a build date of 01/04. I have done a search for info relating to this but all I have found is old and seems to relate to trucks with an older build date.
Problem is.....just recently I have noticed the indicator showing extremely low temps such as 35F 60F 65F etc. when the outside temp is really 85-93. It doesn't do it all the time but when it does my airconditioner blows cool to warm air and my mpg's seem to drop.
Question is......does any one else have this? What have you seen? Have you had it back to the dealer? What was their response and what did they do?
Thanks.
Thanks.
lariatf150 - was your temp reading consistenly of or was it intermittent? Mine works ok 95% of the time. I don't want to go in and get a cannot duplicate. Also, did they reflash the pcm on their own or did you have to ask them to do that? When they reflashed were there any inmprovements or problems introduced?
Mine was constantly reading 5 or 6 degrees over the real temp. The new sensor fixed it.
I asked for a reflash, more or less. I complained of hesitation, which it sort of has...I think all of them do...but anyway, I pretty much figured that would force them to flash the PCM just to say they did something...and they did No issues after the reflash. I don't really notice any difference afterwards.
just dropped the truck off at the dealer. service writer says that they do not have an open issue with the temp indicator system. he pretty much said if it doesnt screw up while they have it theres not much they can do. i asked about the reflash and he said if there is no check eng light on with a code he wouldnt reccomend it. so since it only screws up 10% of the time i am waiting for the call that tells me they couldnt duplicate it.
the dealer ended up replacing the temp sensor. the gauge reads ok so far and the a/c works better. the service writer tells me that there is no relationship between the outside temp indicator system and the performance of the truck. i am not so sure. does any one have a better understanding or knowledge of this?
