Root Cause Of The Vibration Troubles
Root cause of the vibration Troubles
If you look from the driver side rear wheel well with your eye level even with the top of the frame you can't see the rear passanger side tire, Now do the same from the passanger side rear wheel well, you will see the top two to three inches of the driver side tire. The frame is uneven and unbalanced with the axle. Every F150 on the dealer's lot is the same way, this is the crux of the vibration issue. Wake Up FORD
Re: Root Cause Of The Vibration Troubles
Bent frame? Yeah right.
My guess is the small %age of people having problems have issues with the new rack & pinion steering system. Ford had the same problems when they first went to rack & pinion on the Crown Vics and Grand Marquis.
