998 miles- going in today, my "old lady" list to fix
I dropped it off at 7am today, my first service encounter. I had an “old woman’s” list of little things that could be corrected. Virgil was the name of the guy that helped me; he was very good and extremely nice about listening to me and getting me in right away with a loaner vehicle. Here’s my list FYI:
1. Steering wheel vibration starting about 50mph, worse at higher speeds. ( I know those General Ameritrac are crap) I had them road force balanced locally (at my expense because the dealer is 20 miles one way through traffic), and they had to install weights as follows: LF-7.5 oz.; LR-8.5 oz.; RF-9.0 oz; RR 5.75 oz. I suggested that either the tires were bad or the rims were bad. I offered to pay the difference if they put on better tires. He wasn’t sure if they would be able to do that, but he would call me. This is my biggest concern.
2. Excessive break dust (we all know about this). He also seemed to know about this problem and appeared to agree???? Different brake pads used on the Expi and Navigator (I gave him a part #) would take care of it. I found the part# on the F-150 On-Line Forum (BTW, was not a good #). I will have to see what happens.
3. Truck is lopsided. RR is 5/8” lower and RF is ˝” higher. Also the front bumper is on crooked. This was easy to see. May not be a real problem, but it is noticeable.
4. Poor gas mileage (may be my foot). 15mpg highway. No comment on this. I’m hoping a PCM flash will help.
5. Gas gage shows empty and “low fuel” light comes on with still 8 gal. in tank(I have 30 gal. tank). (He wanted to know how I knew that; it took 22 gal. to fill, 30 minus 22.........I'm a little worried).
I must admit, I LOVE this truck! I will post results, hopefully with everything resolved. I will be out of town 'till Monday. Comments and your "true life experiences" very welcome!
Blake
Blake
I picked it up at 10:00 am today (Monday, 8-23-04). Here are the repairs/explanations of my first experience at Ford in their exact words (in italics). (BTW my 1993 Nissan Pathfinder has never had a repair performed except wheel balancing, so I’m being watchful – I nearly bought a Titan (WHAT??).
Rebalanced all tires, all tires required rebalancing. RH side had incorrect wheel weights installed. (Had AL weights, not MC). Measured tires and wheels – check run-out.
Balanced Tires, all tires required rebalancing. RH side had incorrect wheel weights installed. (Had AL weights, not MC). Measured tires and wheels – check run-out.
When I called to pick it up on Thursday, I was informed it was sent out to have road force balancing. Not sure where they took it, but here is the write-up: Tire run out as follows: .050, .048, .045, .040. All tires were marked on the inside of their respective run out. Need to check with manufacturer for allowable run out. Balance (road force) all four tires.
This is a normal condition caused by the design of Fords brake pads, that increase rotor life and brake pedal feel. (The Expi does have improved pads, but they will not fit on the F-150 https://www.f150online.com/forums/sh...+dust+new+pads )
Measured vehicle ride high. Front high is equal side to side. Rear is within .125in side to side. Measured height floor to fender lip on vehicle to check body lean. Front is identical side to side at 36.75” Right rear is 39.75” left rear is 39.675”.
Adjusted front bumper.
EEC test. No codes present. No problem found at this time. (PCM flash done anyway).
I CALLED AND CANCELLED THIS (SEE ABOUE POST)
I must acknowledge, I still LOVE this truck! I took it up to 80 mph today and the vibes are gone; smooth and quiet as can be. I will be able to live with the break dust considering the performance issue; I will try “Mr. Clean” https://www.f150online.com/forums/sh...ght=brake+dust . The bumper is now straight. I will post additional results as they occur. Further observations about your truck and comments are welcome!
Blake
Blake
Re: Thanks, Kingfish!
Originally posted by MtkaBlake
Thank you! I just called (although my manual is with the truck, so I trust you are correct) and they took #5 off the list. I, like a few others, just didn't bother to check the owners manual. Sorry!
MPG
Originally posted by MRILEY
Please let us know about the gas mileage. Did it go up with the PCM flash or is the 15mpg highway a result of leadfootitus...
BTY, ALL my steering wheel vibes are gone! The road force balance, done first by Tires Plus, and then by the dealer (they sent it to Mike's Tires in Little Canada) took care of any steering wheel nibble. It's now like riding on a cushion of air. Unbelievable!
