High Pitched Squeel
High Pitched Squeel
My truck has 13,500 miles on it, Just had an oil change 400 miles ago. For some reason my truck has now developed a high pitched squeel. It occurs when I drive at 51 & 59 mph. If I go any faster or slower than those speeds the squeel goes away. It is present if I have the cruise control on or off, 2wd or 4wd; defrost,heat,ac on/off. I shut the truck completely off and began driving again...but the squeel came back. It sounds as though it is coming from behind the instrument panel in the dash. My truck is an 04 fx4 scab. I would appreciate any ideas as to what it may be so I can get it looked at. Also, unsure if it would have any bearing on the matter...but it is 3 degrees outside, unsure if temperature related.
I have been needing a good excuse to buy the belt from troyer...also be a good time to buy the 1714 i believe...Thank you for the idea I appreciate it and will let you know Also...It did it the entire way home, which was about a 45 minute drive, about 30 miles. It wont do it by just revving the motor. It only wants to do it when driving at the above mentioned speeds..which is really strange
Originally posted by chemgod
Hey D? What's up with the auto descrption under your name? Get rid of the Lariat or what? I guess it could be a Fiat.
S_Service - Hmmmm... if it's not doing it by reving the engine, that kinda shoots the belt theory, doesn't it? Very strange...
I know, it is a hard to describe noise. It is just an extremely high ear piercing squeel. Almost like if you were boiling water on the stove in one of those old fashioned things when it starts to squeel when the steam is coming out of it. I tried tracking the sound down but it was hard to do while driving, and the fact that there was ice on the road. It definitely is coming from the drivers side area though. And i believe it is coming from around where the windshield and dash meet; because it is very faint and hard to hear from underneath the dash.
Re: High Pitched Squeel
Yes! It is because of the cold weather! NO, I still haven't figured out what it is.
Just before I went hunting a couple weeks back, it was a colder morning here, about 0 degrees, and I thought I had noticed it.
Then, when I went hunting, it was sub zero for the whole trip, and when I was driving between 53 and 56 mph, I would here that. My engine rpm was somewhere around 1350 RPM, or in that neighborhood. Is that about when you are hearing it? I would de-activate the over drive, and when the RPM would jump up in 3rd gear, it would stop the noise at the same speed. Put OD back on, and bam, theres that creepy noise again. I was thinking maybe it was the alternator, but it really does sound like it's coming from just behind the dash.
For the rest of you, it is NOT the belt. It is really more like a whistle, or like a mechanical pitch when two pieces of steel make a squeal rubbing together. It is very strange. Its like ghost shrieking in a cheap B-Flick.
Anyway S Service, it's supposed to be colder here again at the end of the week, and I'll have time to dig in a little more. If I find anything, I'll let you know immediately.
