Dead tranny, 96 miles!
Picked up my 2004 FX4 S/C last night. This morning on the way to work I got a TRANS FAULT message while driving 70 on the interstate. Took the next exit and the truck would not go into any gear. The bottom of the truck was covered in fluid!
Only 96 miles on the truck! I am thinking seriously about demanding a different rig; I haven't even turned in the signed paperwork since I had to take it all home to have my wife sign!
Grrrrrr!
Grrrrrr!
Its one part of the truck and no way affects everything else. So you got a F'up tranny. Ford will fix it, and clean up all the fluid. Then you'll probably find it to be the best truck you've ever owned. The problems that can be easily diagnosed are gonna be the ones that don't reoccur cause they will likely be fixed right in the first place. Now if you had a new tranny put in and it went again, and then again and again, go to a different dealer, but hopefully it won't come to that.
Since you haven't signed the papers just get a different truck. Unless you are set on the one you drove home. Tell the dealer you are going to shop around at another dealership that has something similar. I bet they drop the price $500+ for you to sign today on the broken tranny truck...
I bought a dryer last night because the old one died. We brought it home and I installed it. It didn't heat and the start button had to be held down for it to run. I am going to return it tonight and get another one in its place. Why should I have to sit at home for a day for the repair man to come and diagnose a problem and then come back another day to fix the problem?
Since you have the paperwork, I'm sure you can squeeze something out of the dealer if you stick with the repaired truck. Price drop or try and get some accessories for free, or maybe an extended warranty if you didn't already have one. Then again I wouldn't balme you from walking away from that one either. Good luck.
yeah get some free stuff from ford, a better price, accessories something. If they dont wanna talk about it tell em that you really have to do some thinking about whether or not you can put your money into something that broke so soon and walk ur butt on outta there, unless your price was so great that you wont be able to get it anywhere else. Id make a copy of the dealer breakdown to take it with me to another dealer for a price match. When you go to your original dealer make sure u try and get your salesman, he will fight a bit harder for his money than some random guy.
Just got a call from my service advisor...apparently, there is a blown front pump seal!? Was the tranny assembled incorrectly, or what? He said the transmission would be torn down tomorrow, appropriate parts would be ordered overnight, and it might be ready by Tuesday.
What do you guys think? Should I just try to get a different truck?
Originally posted by Arctic Cat F7
It could be a sign of things to come. Hand it back and get another one. That problem will always be in the back of your head if you keep it.
Excellent point. I would get another truck AND try to squeeze something out of them, just because of the inconvienence you went thru. Can't hurt to try. If you decide to try and get another truck, I would do it asap, don't wait till they fix the tranny. I assume they gave you a FREE comparable rental to drive while the tranny is being fixed?
