17" wheels?????
Re: 17" wheels?????
Originally posted by 1BadFX4
whats the deal with 17"s, some say they wont fit on some 04' trucks?? is this true??? cause i wanted to get some factory 17"s and bigger tires to run for the winter...
Originally posted by wandell
Yes, 17's will fit the 04-05. Just think about it. Why would a wheel manufacturer produce a 17 inch wheel in the 6x135mm bolt pattern if they would not fit the only vehicles with that bolt pattern?
I put the standard FX4 17 inch wheel back on my truck and it tows better and rides better. The only change I know of between the 04 and 05 is that on the 05 wheels they stopped putting the index hole in them for the center cap to fit in. The index pin on the center cap is cut off so that it will fit any way you snap it on.
