Granatelli MAF
to my understanding, it flows more air but tricks the pcm into thinking it is running lean to get the extra horsepower out of it, i had one on my 03 5.4 and it seemed to give me some hp, but it causes my engine to run alittle lean and i didnt like that so i went with a lightning maf, good luck
Originally posted by Wilson502
Those MAFs are useless on stock engines. You need a chip or tune to use them.
Originally posted by jasonkola
man bigtruck311 looks like you put more money into mods than you probably payed for the truck. nice truck
yes with the lightning mafs you need a tune, i know this because i also have one of them on my truck also, the grenateli maf is cal for the pcm and the pcm recognizes it and it does not run lean enough to throw a code (pcm can adjust feul 20% with stock 19 pound inj) running the engine leaner but still within the engine pcm adjusting curve is just a way for it to gain some horses, it does not need any chip or tune to function or to produce a hp trq gain, nough said
i still believe its bull hooey, that they say u dont need a chip or tune to use the maf. Any MAF other than stock most of the time requires a tune or a chip to really use it. Im not a big fan of changing MAFs without getting a chip for it, regardless if its replacing it with another OEM type piece or aftermarket.
