Mounting Location of grill/brush guards
Ag,
Just get a ranch hand they look good hold up well, and have 4 mounting spots
Lower 2 you unbolt your towhooks and mount the ranch hand, then replace the tow hooks, the upper brackets wil bolt up in front of your tranny cooler if you raise your hood and look straight down you will see 2 holes in the frame, one is round and one is oblong, thats were the brackets go for the upper support, if you look look at the air space in the middle of your bumper, you will notice what looks like a small screen on each end, these pop out and that allows you to get a rachet up in there, also if you have a front license bracket pull up then out and the 2 top clips will come free letting the bracket swind down and giving you more room. When you get the brackets in just replace plastic parts u popped out.
I got my brush gurard from www.rockingrranch.net , its well made and heavy but if you can find a decent deal on a ranchhand, check Ebay i would go with the RH.
