2.5" Autospring pics
I am worried about being nose high when towing also. To solve this I ordered a set of Timbrens first for $150 to put in the rear. Those will be here soon, then I will install them and load down the truck to see the results. Once I see what it does, my final decision will be made on the leveling kit for the front.
I will keep you up to date to see if this $150 fix works.
Looks much better. I will be installing mine on Saturday. Did you have to completely remove the front shocks from the truck to install the spacers? I thought that the spacer could be mounted on top without removing it from the lower control arm. I guess the back bolt would be had to get to.
Originally Posted by suncoast ford
They are not level from the factory due to the vehicle being a truck, with a bed, with a purpose of hauling a load. A few hundred pounds in the bed and its level!
The next time I want your smartass opinion, I'll give it to you.
NCB
