new cats on a 05 f150?
does anyone know where i can get some high flow cats to replace the ones i have now. encase some of you dont know the 05's have a single cat with the O2 sensor stuck in the middle of it dunno why ford did this. but im just wanting to replace my intake, headers and cats all at the same time should see nice gains with all the airflow i would be getting.
Originally Posted by FX4&EXCURSION
Running without cats is not a good idea. You will lose power. Other than stock, hi-flow aftermarket is the way to go. Not sure of any vendor that makes them though. You can try Bassani or Magnaflow perhaps.
Your signature takes up an entire page, maybe yours should be called a page-ature
Correct
Originally Posted by asinatra
It's a system; that is working together, you wont lose anything if you have the right system, and that mainly deals with the muffler itself.
I personally don't think it's a bad thing ford did this. It sure is better than having 4.
Originally Posted by offroadmaniac
My truck is setup the same. But, I guess all '05s are not this way. I got a lot of replies saying they should have 4.
but i do have 2 more questions.
1. how much in gains do you think i would get from all this and a turner? thinking about the underdrive pullys too (mpg and hp/tq)
2. would it really matter that i have a flowmaster super 40 and not a real performance muffler? i really like the sound for the 40 but would rather have performance now that the new sound of that deep rumble has worn off
Originally Posted by fourpointsix
Get an IMCO 1 chamber. It will still be nice and loud and flows a hell of a lot better than Slowmaster.
I went with magnaflow.
Since they have the o2 sensor mounted on top of the cat, I guess we're stuck with high flow cats, unless the tuner can compensate for removing the sensor.
just added it up it should be around 90-100 rwhp gain hopefully about 4 mpg too if i stay out of the gas gonna cost about 2k for it all biggest part being headers. im amussing they be around 200 for the install no way im doing that myself after hearing the stories here everything else should be easy. im prolly gonna hold out on cats and just go with af1, tbs, magnaflow, headers, and a xcal2. next will either be procharger or whipple (if they ever get off backorder) or some 4.56 gears. prolly will be the gears just cause i dont have the 6-7k to drop for the charger
