Info on Daystar or Auto spring w/ Factory 18"s
I have Talked to a couple of you, and this has been more than likely been posted before And before I go spend a couple of bucks on tires............. I want to do the daystar or autospring 2.5" leveling kit. I also want to run the Largest tires i can on my FACTORY 18s. I Have been told and seen pictures of 35/12.5/18 Any comments problems,pics, or suggestions?
go to www.autospringcorp.com and go to the ebay auction from there... lots of people have done 35's with the 2.5" kits- you may have to trim slightly, not major though.. im running 33's with my 2.5- turns fine, looks good imo.
good luck man-
jj
good luck man-
jj
I've seen 35's on the factory 18" wheels, but IMO it looks stupid. Thats too much tire without enough lift.
It look better with a 33" tire IMO. I've seen guys run 325/60/18 (33") on the factory 18" wheels with no problems, and no rubbing.
Can I play? I've got 34.5 (315/70/17) BFG AT's on the factory 17's with a 2.5" Autospring. Looks perfect in my eyes, no rub, no cutting and plenty of room around the tire so I'm not "stuffed".
Personally, I prefer keeping the wheels/tires tucked underneath the truck and not sticking out beyond the fenders. This will allow your fenders to do their job and you won't be slinging crap all over your sides. The only way you'll accomplish that is by staying with the stock rims or finding an aftermarket rim with the same backspacing/width.
Keep your stockers, wheels should only stick out on low-riders and go-carts.
Just my opinion....
hey black, i was lookin at your picutres in your gallery and i see that you leak too at the cvjoint... i think i only noticed this after i isntalled the autosprint 2'... have you taken it to the dealer about this?. what was your cause, and did you get it fixed?.. whats long term damage on this?
thanks guys..
chris
thanks guys..
chris
thanks guys..
chris
The leak was spotted before I installed the autospring. I only had the truck for about 3 months and when I changed the oil for the first time I noticed the leak. The Ford dealership replaced the gasket and covered the seal with what appears to be a gray RTV material. No leaks since then and I haven't ha any problems out of my 4wd system at all.
