Had a fender bender..Thanks FX4EXCURSION
Those are my numbers
And by the way you will also need the lower air deflector as the old one will be too short.
https://www.f150online.com/forums/sh...57#post1891757
Also i might note [here] your bolts may be larger and with some force you can still use them (air/impact wrench)
FX4&EXCUTSION & asinatra
What was your total bill for all the parts needed? I payed $595 w/tax at my local Lincoln dealer, which included bumper, fog lights and all brackes. My final bill of $595 even included a Harly grill. The only bad thing is I have to wait 2-3 weeks
Would you guys know if the fog lights come with the black plastic ring that is between the front of the fog's and the bumper?
FX4&EXCUTSION & asinatra,
Would you know if I need these part's? INNER BRACKETS (BUMPER TO FRAME MOUNTING) 4L3Z-17B982-AB (RH) 4L3Z-17B983-AB (LH) From what I understand is that the first # in the part # is for the year model, is this correct? If so that would make the parts from a 04 which I have. Are these part's on my truck already?
Thanks for any help you may have.
6L3Z-17B984-AA
6L3Z-17B985-AA
I was close enough
6L3Z-17B985-AA
I was close enough
