Q45 HID Retrofit in 2005 lariat
#31
Originally Posted by HIDPLANET
Duke,
No problem, always glad to help.
Also FYI, I had to edit your thread on the "other" forum.
They havent seen any pics of the truck and its going to make its debut in a video.
Yeah I completely forgot about that. I'm sorry for posting those. Thanks for catching them for me!!!
Hey, one more question. How much room is their between the frame or whatever is behind the headlight and the actual headlight? I'm trying to figure out dimensions of the LS430 and how much room there will be for us to "recess" the projector in the headlight.
Then, did you run your wires along the back on the engine bay for your wiring harness? I was thinking just along the front, but then you get to deal with the fan and all that mess.
Thanks again,
Duke
#32
The position of the bulb on my particular retrofit required me to cut away some of the metal behind the headlight. Took some time but with a cutoff wheel and sawzall it wasnt too bad. I would figure you might have to do the same, but it all depends on placement of the projector. As you may know, there is barely room for the halogen plug back there so its a tight fit reguardless.
I mounted the ballasts directly under each headlight to the frame where the ballasts and covers screwed in securely. Wires were all routed along the same paths as the OEM wiring.
#34
Now I need to think of covers for the denso ballasts. Are OEM HID ballasts normally covered? I'm guessing just putting them to the frame isn't good enought?
#35
#36
Its not really the the bulb sticking out, because mine didnt stick out any further than the halogen bulb, but its the fact that the P32-D connector from the ballasts is bulky and wouldnt fit without cutting.
Do you think I'll be ok by just putting the ballast below the headlight? Or maybe because of my severe winter weather, should I have it covered? It's an OEM lexus ballast that came on the LS430, which I believe is a denso ballast.
Thanks,
Duke
#37
if its prone to harsh weather, I would really seal it up good in some custom housing. You dont have alot of play with that ballast so youre very limited to mounting solutions. There isnt too many places to mount it, and with your limited wire length, you may have to attach it to the headlight itself, or somewhere very close to it.
#38
